Surface Pro 3 dock not detecting external monitor
2014-08-13T15:12:33+00:00
I have a new surface pro 3 and I purchased two docking stations. 1 for the office and one for home. Neither docking stations allows the pro3 to detect a monitor that is plugged into it.   I can plug the monitor directly into the pro3 and it detects if fine both at home and at the office.   I can tell you that its a serious interruption professionally, and personally and does not bode well for MS's desires to serve the business community.   What I need is a solution.
2015-10-25T14:03:15+00:00
hey guys
I had exact same issue and I did this and the issue magically solved!!
a two button restart:
  • Power off the Surface Pro
  • Hold Volume Up and the Power button for 10 seconds
  • Release buttons
  • Wait 5-10 seconds
  • Power on the Surface
2014-08-13T23:38:43+00:00
Hi will-eman,
Thank you for visiting the Microsoft Community! Sorry to know that your Docking Stations are not detecting your external displays. I can certainly understand why this is an inconvenience, especially when, as you mention, it is used in a business environment and for professional purposes. I’d like to help and hopefully provide the best possible solution!
Please try the following:
  • With the Surface and external display connected to the Docking Station, unplug the Docking Station from the power outlet, leave it unplugged for 30 seconds to a minute, then plug it back and see if the displays are recognized.
  • Please make sure all and latest Windows updates are installed. If so, verify all updates were taken while the Docking Station was connected to the Surface.
  • When you connect the external monitor, do you have any other devices connected to the Docking Station as well? And if so, have you tried removing all devices and connecting the external monitor only?
  • Have you tried connecting other external displays to the docking Station? Are ALL displays or devices not recognized?
  • Have you tried the what Ed Bott - MVP suggests?
 Additionally, please read the following support article:
We hope this information works! Please keep us posted!
We are always here to help!
Best Wishes,
191 additional answers
    2015-06-29T21:12:26+00:00
    I have the same problem. I plugged my new Dell monitor into the docking station and it worked for about a day. I was working on it Saturday morning, experienced the same flickering and then my SP3 did not recognize the monitor. I checked the firmware updates, and they are current. I am able to plug the monitor directly into the mini-port on the SP3 and it works well. I plugged a 2nd SP 3 into my docking station and it works well with the monitor plugged into docking station, so I know there isnt a problem with the monitor, or docking station. Has to be a setting or update on my 1st SP3. Looking for suggestions.  Tried mDP to DVI cable and mDP to VGA, same results when using the docking station.
    Update - While troubleshooting this error, I discovered that this error started to happen after the last Windows Update on June 24th 2014
    2015-06-13T22:30:37+00:00
    Now it's not working again. I don't get it.
    2015-05-29T19:16:55+00:00
    After 2 hours on with MS support, they agreed to send me a new docking station, and the external monitor now works.
