Surface Pro 3 dock not detecting external monitor
2014-08-13T15:12:33+00:00
I have a new surface pro 3 and I purchased two docking stations. 1 for the office and one for home. Neither docking stations allows the pro3 to detect a monitor that is plugged into it.   I can plug the monitor directly into the pro3 and it detects if fine both at home and at the office.   I can tell you that its a serious interruption professionally, and personally and does not bode well for MS's desires to serve the business community.   What I need is a solution.
2015-10-25T14:03:15+00:00
hey guys
I had exact same issue and I did this and the issue magically solved!!
a two button restart:
  • Power off the Surface Pro
  • Hold Volume Up and the Power button for 10 seconds
  • Release buttons
  • Wait 5-10 seconds
  • Power on the Surface
2014-08-13T23:38:43+00:00
Hi will-eman,
Thank you for visiting the Microsoft Community! Sorry to know that your Docking Stations are not detecting your external displays. I can certainly understand why this is an inconvenience, especially when, as you mention, it is used in a business environment and for professional purposes. I’d like to help and hopefully provide the best possible solution!
Please try the following:
  • With the Surface and external display connected to the Docking Station, unplug the Docking Station from the power outlet, leave it unplugged for 30 seconds to a minute, then plug it back and see if the displays are recognized.
  • Please make sure all and latest Windows updates are installed. If so, verify all updates were taken while the Docking Station was connected to the Surface.
  • When you connect the external monitor, do you have any other devices connected to the Docking Station as well? And if so, have you tried removing all devices and connecting the external monitor only?
  • Have you tried connecting other external displays to the docking Station? Are ALL displays or devices not recognized?
  • Have you tried the what Ed Bott - MVP suggests?
 Additionally, please read the following support article:
We hope this information works! Please keep us posted!
We are always here to help!
Best Wishes,
191 additional answers
    2015-03-12T17:51:00+00:00
    The only thing I've found that works is to twist the sides of the docking station back and forth until the external monitor is recognized. I have to do this with both docking stations (work and home) I use. Hopefully this isn't causing some kind of damage to either the Surface or the docking station.
    2015-03-12T17:32:15+00:00
    Has anyone found a fix for this :-/
    2015-02-18T21:13:27+00:00
    I am using the adaptor supplied by Microsoft for the Pro3, it works perfectly when connected directly to the tablet and it has worked when conected to the docking station. No amount of jiggling or tilting the tablet in the docking station will make the screen work when connected to the docking station now though.
    This is my second docking station. I will be talking it and the tablet back to the store. I was initially very impressed with this machine as a replacement for a Sony Z but now waiting for Sonys return to the Australian market.
