Surface Pro 3 dock not detecting external monitor
2014-08-13T15:12:33+00:00
I have a new surface pro 3 and I purchased two docking stations. 1 for the office and one for home. Neither docking stations allows the pro3 to detect a monitor that is plugged into it.   I can plug the monitor directly into the pro3 and it detects if fine both at home and at the office.   I can tell you that its a serious interruption professionally, and personally and does not bode well for MS's desires to serve the business community.   What I need is a solution.
2015-10-25T14:03:15+00:00
hey guys
I had exact same issue and I did this and the issue magically solved!!
a two button restart:
  • Power off the Surface Pro
  • Hold Volume Up and the Power button for 10 seconds
  • Release buttons
  • Wait 5-10 seconds
  • Power on the Surface
2014-08-13T23:38:43+00:00
Hi will-eman,
Thank you for visiting the Microsoft Community! Sorry to know that your Docking Stations are not detecting your external displays. I can certainly understand why this is an inconvenience, especially when, as you mention, it is used in a business environment and for professional purposes. I’d like to help and hopefully provide the best possible solution!
Please try the following:
  • With the Surface and external display connected to the Docking Station, unplug the Docking Station from the power outlet, leave it unplugged for 30 seconds to a minute, then plug it back and see if the displays are recognized.
  • Please make sure all and latest Windows updates are installed. If so, verify all updates were taken while the Docking Station was connected to the Surface.
  • When you connect the external monitor, do you have any other devices connected to the Docking Station as well? And if so, have you tried removing all devices and connecting the external monitor only?
  • Have you tried connecting other external displays to the docking Station? Are ALL displays or devices not recognized?
  • Have you tried the what Ed Bott - MVP suggests?
 Additionally, please read the following support article:
We hope this information works! Please keep us posted!
We are always here to help!
Best Wishes,
191 additional answers
    2014-08-21T18:23:36+00:00
    This is the exact same situation both my father and I are in.  We both have the same setup: SP3, Dock, Samsung 28" 4k monitor.  Neither one of us have anything showing on the monitor, but both work just fine when hooked up directly to the SP3, albeit not at full 4k resolution unfortunately.  At this point I want a huge apology and some sort of compensation from Microsoft because we each spent about $600 on monitors because the SP3 was advertised as 4k capable.
    2014-08-21T18:19:24+00:00
    I've manually installed all of these drivers. Still no dice when connecting to a Samsung 4k display. I reiterate that this display works fine with other computers @60 and 30hz.
    2014-08-21T14:03:02+00:00
    I have the same issue, I even swapped out cables to make sure that's not the problem.  The monitor is just not detected.
    I also went and swapped out the docking station at the MS store, but that didn't solve the problem.
    They even tested it on one of their monitors in the store and it didn't work.
    I have an AOCC I2757Fh LED monitor at 1920 x 1080 .  I have all windows updates installed.
