I have the same question. I want to find out the specs. None of the replies answer the question... what wattage output can the MS Surface Go 3 handle? How can I tell if a USB C hub to connect a USB thumbdrive or /and an external monitor will work? I have tried two and get the message that the USB C Hub requires more power than the MS Surface Go can output... but how do I find out what the MS Surface Go wattage output is?
Thank you for your guidance!
