Thank you for reporting the issue. A fix is available through Windows Update. For more information about updates for your Surface available through Windows Update see the Surface Pro 8 update history page.
Surface Pro 8 camera issues; have to constantly disable and re-enable camera driver to get it to work
I've had an on-going issue with my surface pro 8 since I first got it about 20 months ago. The camera will stop working, light will stay on. This happens quite frequently, up to a few times per hour sporadically while using the camera. I've only really been bothered by this more recently as I've been using the camera more for work.
Both front and rear-facing cameras will cease working when this happens.
Disabling and re-enabling the camera driver solves the problem temporarily, making me think it's a driver issue. I've previously attempted to uninstall and install the latest drivers to no effect.
Thank you for your time in this matter.
Surface | Surface Pro | Sound and camera
51 additional answers
2024-06-26T15:08:49+00:00 I purchased my Surface Pro 8 in October 2022 and ever since I have had trouble with the camera working. I have spent countless hours on the phone with technical support who has assured me each time , "it will never happen again" only for a week or two to go by and the camera doesn't work. I cannot get it to work for Zoom. I was told it was a known issue but there is no solution? I work from my Surface Pro for my job and have to be able to attend Zoom meetings, on camera, on the go. This has been a huge issue. I spent a lot of money on this computer for it to not work for the main purpose I need it to. Today, I have tried to get ahold of customer support either via chat or phone call for an hour now and cannot get anyone to respond. I was so kindly told by the automated service that my computer is now out of warranty and I can purchase help if I would like. Are you serious? I need to pay for support to get the camera on this computer working when it hasn't worked properly since I got it? You can see ALL the request tickets that have been put in. This is very frustrating and such a waste of time. It always takes hours to get support. I need some kind of help for this and for it to be resolved for good. This isn't good customer service or support. I have done ALL the things you recommend, and so have your employees who have supported me in the past and nothing works. I need a solution.
2024-06-20T08:53:30+00:00 It seems you're right... I only see this for 7+
I'm afraid you just have to wait good news here Surface Pro 8 update history - Microsoft Support
Sorry!
2024-05-09T13:10:36+00:00 Same issue for me on my SP8.
That has forced me to turn Windows Hello off.
And is making the new Teams unusable. Which is a bit concern now that we are migrated to this app.
Microsoft please assist, this has been on for months.
2024-01-12T00:04:04+00:00 Hi SP8 Camera problems,
I'm sorry to hear that you're experiencing issues with your Surface Pro 8 camera. Based on the information you've provided; it does sound like a driver issue. Let’s work together in finding the best solution to this issue.
Here are some steps you can try to resolve the issue:
- Run the automated camera troubleshooter in the Get Help app. Get Help automatically runs diagnostics and takes the correct steps to fix most camera issues. Open Get Help and select Camera from the list of options. Then, select Run the troubleshooter
- Check for Windows updates: Make sure your Surface Pro 8 is up to date with the latest Windows updates. Sometimes, updates can include fixes for known issues.
- Reset the camera app: Go to Settings > Apps > Installed apps > Camera > Advanced options > Reset. This will reset the camera app to its default settings.
- Make sure that Camera access and Let apps access your camera are set to On. To do this, select Start > Settings > Privacy & security > Camera.
- Go to Device Manager, locate the camera driver, right-click on it, and select "Update driver." You can also try downloading the latest driver from the Microsoft website.
- Next, download and install the driver pack on your Surface Pro8. to update the hardware of the device.
- Once the installation is complete, restart the Surface to apply changes and then test the camera once the device is back on.
I hope this helps resolve your issue. Let me know if you have any further questions or concerns.
Kind regards,
Christopher.
