Logitech K810 and new Surface Pro 3 firmware update not playing nicely Bluetooth Problem
2014-09-17T14:52:37+00:00
Hi there,
There's an active discussion over on the Surface forums regarding the 9/9/2014 firmware update causing Bluetooth issues, primarily w/ the K810 (but I'd imagine this could be w/ other BT keyboards as well).
http://www.surfaceforums.net/threads/logitech-k810-keyboard-and-9-9-14-firmware-update.11391/
Prior to this firmware update I was able to use my Logitech K810 without issue with my Surface Pro 3. However, now it just goes into a connect/reconnect loop. I'll see "driver error" briefly. And then it'll try connecting again.
Looking into the event log for Administrative events, I see this:
Bluetooth HID device  either went out of range or became unresponsive.
I also see another event within seconds that says this:
Metadata staging failed, result={66F5F5A4-2104-53C0-BCDF-9DD1AF9AE33F} for container '0x80070490'
All of this appears to be an issue with the driver and/or firmware.
Furthermore, the keyboard works when pairing (typing in the keycode), but immediately after pairing it fails. So there is certainly something wrong and I don't believe it's the keyboard.
Anyone?
-Steve
2014-10-06T18:36:55+00:00
Hi all, I just installed the 10/6/2014 System Hardware Update this morning and appear to be having no issues with my Logitech Keyboard anymore.  You may want to installed it.
You want to give a try.  So far, no issues encountered.  Hoping it stays that way.  ;-)
Hope this helps!
73 additional answers
    2014-09-20T20:57:46+00:00
    Uninstalling SetPoint (Logitech driver software) seems to be working for me, too, but it's a poor solution, as it means I no longer have access to the settings it enabled, namely using the function keys without using the FN button.
    2014-09-21T02:57:52+00:00
    I can confirm that uninstalling the SetPoint software does allow the K810 to function...but the caps lock causes things to go haywire.
    2014-09-22T04:01:52+00:00
    Hi Steve,
    I have the exact same issue.
    Here's what I learned:
    • Connected the K810 to Surface 3 Pro -> Same Problem with not connecing/disconnecting/driver error
    • Deinstalled Setpoint Software on Surface Pro 3 -> Connection established, Capslock results in weird disconnecting behaviour - only tested for 10 Minutes but anything else seems to be stable
    • Connected the K810 to my Windows 8.1 Desktop PC with ASUS Bluetooth and Setpoint installed (works just fine)
    • Disabled Capslock ability and changed the F#-Keys behaviour in Setpoint on that PC
    • Reconnected it to Surface 3 Pro -> Suddenly Capslock works as it should and the keyboard stays connected (so far. I only tested that for an hour or so)
    Hope this might help. It seems that the new Surface Bluetooth driver and the Setpoint Software interfere with each other. I have not yet reinstalled Setpoint on the Surface 3 Pro. I suppose the problem will come back as soon as you do so I stick with it until either Microsoft fixes Bluetooth or Logitech fixes Setpoint.
    Cheers,
    c6ke
    I had essentially the same experience.
    With Setpoint software active- rapid connect/disconnect cycles.  If it disconnects when a key is being pressed, that key keeps repeating until it reconnects... really annoying.
    If I exit the Setpoint software, it disconnects far less frequently, but still often enough to be annoying.  The problem is, I also have a Logitech mouse, so if disable Setpoint, all my extra mouse buttons become useless.  "Keyboard" used to show up in Setpoint, but it no longer does.
    thanks,
    TjD72
    2014-09-22T12:31:28+00:00
    I'm getting the same error 'Bluetooth HID device  either went out of range or became unresponsive.'
    I'm using a Microsoft Wedge mouse and Jabra headset on Surface Pro 3. It's very annoying all bluetooth devices are disconnecting every few minutes. :(
