Logitech K810 and new Surface Pro 3 firmware update not playing nicely Bluetooth Problem
2014-09-17T14:52:37+00:00
Hi there,
There's an active discussion over on the Surface forums regarding the 9/9/2014 firmware update causing Bluetooth issues, primarily w/ the K810 (but I'd imagine this could be w/ other BT keyboards as well).
http://www.surfaceforums.net/threads/logitech-k810-keyboard-and-9-9-14-firmware-update.11391/
Prior to this firmware update I was able to use my Logitech K810 without issue with my Surface Pro 3. However, now it just goes into a connect/reconnect loop. I'll see "driver error" briefly. And then it'll try connecting again.
Looking into the event log for Administrative events, I see this:
Bluetooth HID device  either went out of range or became unresponsive.
I also see another event within seconds that says this:
Metadata staging failed, result={66F5F5A4-2104-53C0-BCDF-9DD1AF9AE33F} for container '0x80070490'
All of this appears to be an issue with the driver and/or firmware.
Furthermore, the keyboard works when pairing (typing in the keycode), but immediately after pairing it fails. So there is certainly something wrong and I don't believe it's the keyboard.
Anyone?
-Steve
2014-10-06T18:36:55+00:00
Hi all, I just installed the 10/6/2014 System Hardware Update this morning and appear to be having no issues with my Logitech Keyboard anymore.  You may want to installed it.
You want to give a try.  So far, no issues encountered.  Hoping it stays that way.  ;-)
Hope this helps!
73 additional answers
    2014-10-07T01:33:36+00:00
    Yep! I can confirm that my problems are fixed, at least so far! yay!
    2014-10-07T01:50:57+00:00
    Confirming that the 10/6/2014 System Hardware Update also fixed my K810 issues as well.
    Thanks, Microsoft!
    2014-10-07T01:57:41+00:00
    Nevermind, still having issues after installing SetPoint. Uninstalled and back to normal. Caps button still causing issues. Can anyone confirm similar issues?
    2014-10-07T03:24:03+00:00
    Even after the update of the drivers I'm still having problems with the Logitech K8 10 keyboard
