Surface book 2 15 inch 256G super low wirte speed
2017-12-18T02:23:09+00:00
My surface book 2 (15 inch, i7, 16G, 256G ssd) shows high read speed (~3000 mb/s), but super low write speed (~330 mb/s).  I returned my 1st one due to this super low write speed, but 2nd one also show almost same benchmark speed. Based on other reviews, these numbers are consistently reported in 256G ssd model. I wonder if this write speed is normal or it can be improved by firmware update later. If this write speed is normal...why MS used this ssd?. 300mb/s write speed is much slower than my 2yr old surface pro 4 256G (~1000mb/s) and 3yr old 256G ssd(~800mb/s) in my desktop....
    2018-01-26T21:37:27+00:00
    What tool are you using to measure the speed?
    2018-01-26T21:43:40+00:00
    I used CrystalDiskMark 6.0.0
    2018-01-26T22:09:13+00:00
    My 256G SSD is samsung MZFLW256HEHP-000MV.
    My surfpace pro 4 has a Toshiba 256G SDD. Below is today's result (show only sequential writing reult).
    1. Surface book 2 256G : Read 2494.1 MB/s, Write 338.7 MB/s
    2. Surface Pro 4 256G    : Read 1616.3 MB/s, Write 942.2 MB/s
    2018-01-26T22:38:57+00:00
    Have you enabled "Turn off Windows write-cache buffer flushing" in the SSD policies?
    2018-01-26T22:57:44+00:00
    These are the results I got in mine with the write-cache off:
