Surface Pro 5 fan stops working after installing firmware update
2019-01-03T11:40:57+00:00
Hi
I have a Surface Pro 2017, i7, 8GB, 256 but in recent month the fan is not turning on in any working condition. previously I can heard easily the sound of the fan but now its not turn on anyway.
2019-02-07T02:12:41+00:00
Hi saiedbaran,
Thank you for your feedback. We understand your concerns and have been investigating. An update has been flighted to Windows Insiders that we believe addresses this problem and are evaluating that update for release on Windows Update.
Please stay tuned and continue to check for Surface and Windows Updates to ensure your device has the most current firmware and software available.
Note: Marking as "Answered" to raise visibility for now. We will update this response once the fix has been published.
Greg
58 additional answers
    2019-01-21T21:55:40+00:00
    Curious------where did you buy the fan? Can you provide me with a link?
    Thanks!
    2019-01-21T22:05:58+00:00
    My colleague uses it during the summer time, I gladly borrowed it. No idea where he got it from, however if you do a search for USB desk fan, you'll find a lot of them ;-)
    2019-01-21T22:13:48+00:00
    Thanks... This problem caused me to do a warrenty exchage, which is kind of good as the battery in my previous one is failing.
    Also I have contacted MS Surface support about this in chat, said they will look into it.
    2019-01-25T12:32:29+00:00
    Sorry, you cannot uninstall or revert Surface firmware.
