Surface Pro 5 fan stops working after installing firmware update
2019-01-03T11:40:57+00:00
Hi
I have a Surface Pro 2017, i7, 8GB, 256 but in recent month the fan is not turning on in any working condition. previously I can heard easily the sound of the fan but now its not turn on anyway.
2019-02-07T02:12:41+00:00
Hi saiedbaran,
Thank you for your feedback. We understand your concerns and have been investigating. An update has been flighted to Windows Insiders that we believe addresses this problem and are evaluating that update for release on Windows Update.
Please stay tuned and continue to check for Surface and Windows Updates to ensure your device has the most current firmware and software available.
Note: Marking as "Answered" to raise visibility for now. We will update this response once the fix has been published.
Greg
58 additional answers
    2019-06-25T06:31:07+00:00
    This issue is OS independent. It is either caused by hardware, such as a broken heat sensor, or a bug in firmware which executes the fan logic independently from OS.
    My issues were half resolved with a newer firmware update, the prolonged high temperatures had caused a permanent degradation of the system, and the device was exchanged. After that I moved on to a Surface Pro 6.
    2019-06-25T03:58:26+00:00
    Mine works on 1903 18362.175.
