Surface Pro 3: Internal clock stops when the battery dies
2014-08-16T13:54:40+00:00
Is there a separate internal battery for the internal clock in the SP3 running Windows 8.1? When the unit runs out of battery power and I don't notice (for example, the battery completely drains while in standby) when I plug the unit back in the clock still reads from when I last used it rather than the current time.
Is that normal?
Thanks!
Carlos
2014-08-21T00:05:49+00:00
Hi Carlos & Woodg,
I appreciate your comments and I can certainly understand the confusion. Please let me clarify my previous comment:
The Surface Pro 3 includes built-in functionality to prevent incorrect system times when the main battery is depleted.  If the troubleshooting I provided on Aug 16, 2014 fails to address the system time inconsistencies, please reach out to our Surface Assisted Support.
Any other questions or concerns, please don't hesitate to visit the Community!
Best Wishes,
2014-08-17T02:45:05+00:00
Hi Carlos,
On behalf of the Microsoft Community, we thank you for taking the time to reach out and consult this issue. I gather from your post that after an unexpected shutdown the clock on your Surface Pro 3 won’t update automatically as it should. This is indeed irregular behavior, and as such, I understand your concern. I will do my best to help and clarify your doubts!
Please check the following:
  • Do you have all and latest Windows updates installed? This is very important, Please verify you do.
  • Does a full shut down and start allow the clock to return to accurate local time?  Have you tried adjusting the time manually?
  • What happens if you do not set the time to set automatically?  Does your manual correction of the time stay set?
  • Swipe for Charms> Settings> Change PC settings> Time and language> Date and time> Set time automatically> Off
  • Do you use any other Windows 8.x devices with the Microsoft account associated to Surface?
  • Try un-syncing the OneDrive settings: Swipe for Charms> Settings> Change PC settings> OneDrive> Sync settings> Sync your settings on this PC> Off
Additionally, please make sure that you have checked the box next to: "Synchronize with an Internet time server". Here is how:
  1. From the Desktop menu select the time and date at the bottom right corner.
  2. Tap on Change date and time settings...
  3. Select the "Internet Time" tab.
  4. Select Change Settings.
  5. Check the box next to "Synchronize with an Internet time server".
  6. Select Update now.
  7. Then select OK and OK.
  8. You can also try a different server by synchronizing it with the time.nist.gov server (instead of time.windows.com) and then select****Update now.
  • As a last step, try holding down the "Volume UP" and the "Power Button" at the same time for about 15 to 20 seconds.  It should do a reboot and if no activity, release and 'click' the power button one time.
If the issue persists after the previous steps, please consider performing a Refresh as shown in the article below:
We hope these steps prove useful! Keep us posted!
We are always here to help!
Best Wishes,
73 additional answers
    2015-05-01T11:07:52+00:00
    so, i did the factory reset (the "short" one), without effect - when not connected to a power source, time stops upon shutdown.
    some observations and thoughts -
    time stops and is not random, on which behavior for which i would not immediatly conclude a power loss for the clock, if the clock lost power, why would it restart where it was, and not on the 01/01/1970 ? why would the "stopping time" be saved? --> could still be a software bug.
    After the "short" factory reset, all my data was gone, but somehow my desktop wallpaper and login screen were still there. could be that this is saved to skydrive/ onedrive/ whatever the MS cloudservice is called currently. This occurred even with me explicitly stating during setup that i don't want to use the cloud (for now).
    I'm wondering if this bug might be backed-up in the cloud as well... is there a way to reset my onedrive account?
    The good news is that the replacement service seems to be well organized, and although i've read about it several times, it doesn't seem to happen to too many devices.
    Cheers!
    Carl
    2015-05-01T11:24:35+00:00
    the "do you want to use the cloud" is for document/photo storage, not settings.
    To unhook from the settings that control wallpaper/login screen, you need to go
    to Start, Settings, Change PC Settings, OneDrive, Sync Settings.
    Barb
    Windows Experience MVP
    2015-05-01T12:46:16+00:00
    Hi SCGerodie,
    makes me wonder 2 things
    1. i'm actually wondering about the percentage of units that have these kind of issues,
    2. and whether it's really hardware-related or if it's not some kind of Win8 bug, when switching between different clocks when in different power modes in the connected standby...
    Regards, Carl
