Surface Pro 3: Internal clock stops when the battery dies
2014-08-16T13:54:40+00:00
Is there a separate internal battery for the internal clock in the SP3 running Windows 8.1? When the unit runs out of battery power and I don't notice (for example, the battery completely drains while in standby) when I plug the unit back in the clock still reads from when I last used it rather than the current time.
Is that normal?
Thanks!
Carlos
2014-08-21T00:05:49+00:00
Hi Carlos & Woodg,
I appreciate your comments and I can certainly understand the confusion. Please let me clarify my previous comment:
The Surface Pro 3 includes built-in functionality to prevent incorrect system times when the main battery is depleted.  If the troubleshooting I provided on Aug 16, 2014 fails to address the system time inconsistencies, please reach out to our Surface Assisted Support.
Any other questions or concerns, please don't hesitate to visit the Community!
Best Wishes,
2014-08-17T02:45:05+00:00
Hi Carlos,
On behalf of the Microsoft Community, we thank you for taking the time to reach out and consult this issue. I gather from your post that after an unexpected shutdown the clock on your Surface Pro 3 won’t update automatically as it should. This is indeed irregular behavior, and as such, I understand your concern. I will do my best to help and clarify your doubts!
Please check the following:
  • Do you have all and latest Windows updates installed? This is very important, Please verify you do.
  • Does a full shut down and start allow the clock to return to accurate local time?  Have you tried adjusting the time manually?
  • What happens if you do not set the time to set automatically?  Does your manual correction of the time stay set?
  • Swipe for Charms> Settings> Change PC settings> Time and language> Date and time> Set time automatically> Off
  • Do you use any other Windows 8.x devices with the Microsoft account associated to Surface?
  • Try un-syncing the OneDrive settings: Swipe for Charms> Settings> Change PC settings> OneDrive> Sync settings> Sync your settings on this PC> Off
Additionally, please make sure that you have checked the box next to: "Synchronize with an Internet time server". Here is how:
  1. From the Desktop menu select the time and date at the bottom right corner.
  2. Tap on Change date and time settings...
  3. Select the "Internet Time" tab.
  4. Select Change Settings.
  5. Check the box next to "Synchronize with an Internet time server".
  6. Select Update now.
  7. Then select OK and OK.
  8. You can also try a different server by synchronizing it with the time.nist.gov server (instead of time.windows.com) and then select****Update now.
  • As a last step, try holding down the "Volume UP" and the "Power Button" at the same time for about 15 to 20 seconds.  It should do a reboot and if no activity, release and 'click' the power button one time.
If the issue persists after the previous steps, please consider performing a Refresh as shown in the article below:
We hope these steps prove useful! Keep us posted!
We are always here to help!
Best Wishes,
73 additional answers
    2014-12-10T14:17:15+00:00
    I'm having problems with the clock not keeping in sync on my SP3 i7. I usually use Hibernate and sometimes Sleep, the bug seems to be with both.
    Come on Microsoft get this fixed please. This device was supposed to be my "laptop replacement" but I've had to go back to my laptop... not a happy customer!
    2014-12-16T15:37:12+00:00
    I too have the same problem with the clock, but this failure started some time ago (6 months or so), probably as a result of a famous "Update".  For this reason WE did a complete RESET along with a MS store technician, to no avail.  Also my Windows icon on the bottom of the bezel died, also some time ago, and can not be fixed unless I send it for repairs at a cost of $300!!!!!!!!!!!!!!! because my unit is 6 months out of warranty.  I was offered $150 credit towards an upgrade to a new unit!
    This problem is starting to sound like the GM recall: Lies and more lies.  This is a software problem they can't fix.
    I hope this gets to the right desk!
    2014-12-25T05:29:45+00:00
    Is there a solution yet?  I'm too having clock stop issue when in hibernate or shutdown (power off) and the ac power cord unplugged.
