On Fri, 21 Nov 2014 18:19:35 +0000, EddieN77 wrote:
>>The 2.4Ghz connection was showing a link speed of 117Mbps and I was able to browse the web normally.
so does this mean your speed is what you expected and you are happy?
Barb
The 2.4Ghz link is still slower than it should be (based on other devices using the same SSID) but it works now. I have about a dozen SP3s at work that I'm going to upgrade and then test with Cisco 3501 APs. These are 2.4Ghz 802.11N access points. I'll let you know what I find next week.
