After I completed the mentioned steps I could see (in Device Manager) that the three items I had previously uninstalled were back. The O/S used the local version of those drivers to install them.
As for Windows Updates, I didn't see anything right away. If you have it check for new updates you will likely see the important update from 6/19 reappear for installation. Again, don't install this. If you do you will be right back where you started.
