Surface Pro 3 Slow WiFi - 72Mbps Max (driver)
2014-06-21T05:48:07+00:00
I have an Apple Airport Extreme 802.11ac wireless router at home and am only connecting at a max of speed of 72Mbps (usually closer to 11Mbps if I'm more than 20 feet away from the WAP). I have two other 802.11ac laptops at home (Samsung AB9+ and rMBP) and my two other computers are connecting up at 800Mbps+ and pulling down the same on Internet speed tests; yes, I have real GigE connectivity. Is anyone else having these problems?
  1. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2014-09-12T10:16:35+00:00
    On Fri, 12 Sep 2014 05:42:04 +0000, Martynas_B wrote:
    >>Can it be some frequency ranges incompatibility between US and Europe?
    where are you located and where did you purchase your SP3?
    see http://en.wikipedia.org/wiki/List_of_WLAN_channels
    Channels 1-11 are what is normally supported in North America.
    Are you traveling in Europe or elsewhere where 12-13 are in use?
    Barb
  2. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2014-09-12T10:20:07+00:00
    On Fri, 12 Sep 2014 01:56:06 +0000, Kahmeal wrote:
    >>I have a Netgear RT-AC68U router at home and have experienced identical results in that the wireless card refuses to select the 5ghz band (AC) when both bands share the same SSID. When separated, there is no issue connecting at a full 700+mbps and transfers peak around 30mb/s depending on how close I am to the router. I have not tested with a single SSID since the firmware update on the 9th but will do so either tonight or tomorrow and post my results from both scenarios at an equal distance to the router.
    That model number looks like ASUS, but anyway, it seems to be pretty universal
    that the Surface Pro 3 connects to the 2.4GHz band when the SSID is the same for
    both 2.4 and 5 GHz.
    Until such time as Microsoft makes a change to fix this (IF they make a
    change) the only way to insure that you connect to the faster AC band is to
    specify separate SSID names. And yes, I recognize that other devices don't
    suffer from this issue.
    Barb
    2014-09-12T11:10:10+00:00
    So the Marvell AVASTAR network controller in the Surface Pro 3 will never join the 5GHz band of a 802.11 AC router if the SSID is identical for both the 2.4 and 5GHz bands. Once the SP3 connects to the 2.4GHz band it will cap the connection speed to 144Mbps unless you disable bluetooth. This behavior is happening AFTER Microsoft just released an update to address wireless performance. All I can do is shake my head over this.
    2014-09-12T13:49:06+00:00
    As I wrote above, we purchased a Surface Pro 3 (i7-256GB) in the first couple of days of August, but unfortunately the Wifi device inside the tablet seems to be seriously malfunctioning to this day and after this week's firmware update.
    While the hourly resets have stopped, the connection is running at extremely slow transfer rates -- sometimes much slower even than the slow "speed" described in the "Wi-Fi Status" window.
    Compared to other laptops and devices in the same location the Surface Pro 3 is very slow. For example, the Surface Pro 3 shows 24.0Mbps, but the laptop (a 2005 Dell Vostro) was experiencing no issues and was running at 130 Mbps.
    Our test network was a Verizon FiOS setup using the Actiontec MI424WR-GEN3I router in 802.11n only mode.
    As stated before, our Surface Pro 3's lot number/date is 1428. All firmware updates and windows updates are installed as of 12 September 2014.
  5. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2014-09-12T15:34:39+00:00
    You've probably read all the complaints about slow speeds with the 2.4GHz band
    in this thread.
    There's really been no definitive comment from Microsoft on this issue, only
    references to a better user experience with the latest September updates.
    If it were me, I'd be livid, but I'd bite the bullet and get a really good ASUS
    or Netgear 802.11ac router and run it in Access Point mode and attach it to a
    port on the Verizon router. I'd specify separate SSIDs for 5 and 2.4GHz and
    connect my SP3 to the new 5 GHz SSID.
    the MI424WR-GEN3I is ancient in router years. Verizon will sell you a better
    FIOS router for $75-$100 but you are better off with your own device.
    I DO realize that the issue is with the SP3. But absent a fix from Microsoft and
    the lack of specific comments on this specific issue from Microsoft, I'd
    probably spend the money. This isn't a real answer to the lack of
    attention/fixes, but it is the only thing I can suggest.
    I can personally vouch for the Netgear R7000 and the ASUS RT-AC68U. There are
    some cheaper routers that can be run in AP mode that may work ok, but I don't
    have personal experience with them.
    Barb
