Hello. After 18 hours of applying the patch the network card decided to stop working and required a reboot to get it working so I guess this is not fixed yet. It is better than every 4 hours but by far not fixed yet sorry. this is what happens. See image.
Surface Pro 3 Slow WiFi - 72Mbps Max (driver)
I have an Apple Airport Extreme 802.11ac wireless router at home and am only connecting at a max of speed of 72Mbps (usually closer to 11Mbps if I'm more than 20 feet away from the WAP). I have two other 802.11ac laptops at home (Samsung AB9+ and rMBP) and my two other computers are connecting up at 800Mbps+ and pulling down the same on Internet speed tests; yes, I have real GigE connectivity. Is anyone else having these problems?
2014-09-11T01:36:18+00:00 -
2014-09-11T03:54:08+00:00 Could you post the same picture but using different SSID for both bands? I'm just curious.
Sure thing. Here's the same setup except the 5 GHz band has a dedicated SSID, and both machines are closer to the router.
So much better...!
2014-09-11T11:16:14+00:00 Could you post the same picture but using different SSID for both bands? I'm just curious.
So much better...!
That's why other OEMs like Netgear or Asus use different SSID.
2014-09-11T19:35:12+00:00 I'd much rather have a clean single SSID network. Is there a downside to making the Surface prefer the frequency with better bandwidth like the rest of my computers?
2014-09-11T19:44:03+00:00 I have a sp3 with the 9/9/14 firmware update...at home I have no problem, IF i have one ssid for the 2ghz band and a complete different ssid for the 5 ghz band. If i choose to connect to the 5ghz ssid it connects at 866mbps, in other words wireless AC.
At work is another story we have multiple access points using the same SSID for both bands. It seems like when you have the same ssid for both bands its automatically selects the 2ghz band in lieu of the 5ghz band. Its kind of funny that we put an access point right beside the surface at only 5ghz band. The others access points had 2ghz band and 5ghz band no matter how many times i disconnect and connect the wifi and connect to the same ssid it automatically select one of the access points on 2ghz band even if it was 100 feet or more away. We disconnect that access point and automatically select another access point that was on the same 2 ghz band that was a little closer.
So in other words the surface pro 3 behavior is that is selecting the 2 ghz band not the 5ghz if the ssid are the same. The only way to force it is to create a different ssid for 5 ghz band. Thats why you only see 144mbps or less using the same ssid because i guess is using Wireless N 2ghz at 150 mbps. Wireless AC does not work on 2ghz band.
Those are my finding. I dont know why Microsoft have taken son long to fix this issue. I don't think is hard to fix. Other wireless AC adapters have better logic on selecting the best connection.
