On Fri, 8 Aug 2014 12:46:11 +0000, newpop1 wrote:
|My router is a Linksys WRT1900AC and I also tested with a Dlink AC router, I
think it was the DIR-868. I was testing that router for work but the results
with the SP3 were the same. I was able to have somewhat reliable connectivity
to an older Dlink Mycloud G router after they released the first update but then
it never worked properly after all the updates to *any* router.
|I even went to a home with a DIR-655 Dlink router and SP3 would stay
connected for 2-3 hours OK then then the upload speed would be almost non
existent and it would drop to Limited Connectivity eventually. And this is with
the latest windows updates to date.
what channels did you set the 1900AC to? Or did you use auto select (same
questions for the other routers you tried). I'm wondering if setting an explicit
channel (as well as explicit different SSIDs for the two bands for those routers
that out of the box use the same name for both) has any bearing on what folks
are seeing.
I have to say that I returned a 1900AC as being the worst AC router on the
planet for features and stability. I don't know if the latest firmware fixes
anything, but I was appalled at the lack of a backup and restore settings
function for starters.
Barb
Barb's Connected World Blog Reader Windows 8 App -
http://apps.microsoft.com/windows/en-us/app/barbs-connected-world-blog/02f35769-52bf-461c-b1d5-06e54a58d298
