On Wed, 23 Jul 2014 09:37:06 +0000, Ilia_972 wrote:
|Yesterday I bought a new MS Surface Pro 3 (128GB). I wanted it as a
replacement to my old Acer W500 upgraded to Win 8. So I spent whole day loading
some WinStore Apps and Desktop Apps. About 20 GBs. I noticed my downloads
progressed very very slow. So today I checked speed of my Internet connection. I
have a router that provides Internte access to 2 desktop PCs via cable
(ethernet) and to various devices via WiFi. I pay for about 50 Mbps speed.
Speedtest results showed that my PC has a strong 61 Mbps connection, my old Acer
tablet achieved only 12Mbps (WiFi) and my brand new Surface Pro 3 - only
4Mbps(!).
|I still stuck with updating my Google Drive and OneDrive folders on SP3. If I
go to TaskManager/Perfomance, WiFi tab shows that my speed is capped at 4.1Mbps
no matter how much apps are downloading stuff from net.
|Surfing on web and googling showed that some owners experienced same problems
after some update, but I received my SP3 few days ago, so, probably, this update
was already installed, because my WiFi issues began right after I turned on my
tablet.
|So the question is: Is it possible that there are some kind of additional
settings I have to fine tune to make WiFi connection faster? Or are there some
kind of brand new prerequisites for SP3 that my router doesn't meet?
There are several long threads about this. See
First, you should manually check for updates as many times as you need to until
Windows Update reports no more available updates. There have been two releases
of drivers and firmware to fix WiFi issues. Unfortunately, they have not
completely fixed the issue and some folks still have problems.
Barb
Barb's Connected World Blog Reader Windows 8 App -
