Uninstalling the driver, deleting and doing a reinstall did not resolve the issue for me. sometimes WiFi goes to limited connection while I'm surfing . this is getting irritating . I really hope this is resolved soon. I don't have a AC router either.
Surface Pro 3 Slow WiFi - 72Mbps Max (driver)
I have an Apple Airport Extreme 802.11ac wireless router at home and am only connecting at a max of speed of 72Mbps (usually closer to 11Mbps if I'm more than 20 feet away from the WAP). I have two other 802.11ac laptops at home (Samsung AB9+ and rMBP) and my two other computers are connecting up at 800Mbps+ and pulling down the same on Internet speed tests; yes, I have real GigE connectivity. Is anyone else having these problems?
2014-06-30T00:02:54+00:00 -
2014-06-30T15:26:16+00:00 I am also still having the slow WIFI problem. I am getting a consistent 3 Mbps download speed. Other devices are getting 50+ Mbps download My router is Linksys E1500 Type-N 2.4 Ghz. I do not have 5 Ghz type N router or AC router. I tried all solutions on the forums (here and on surfaceforums.net) including upgrading my router firmware.
I am also hoping for a driver update that will resolve my problem. If not I will return the SP3 before the warranty expires.
I am also considering upgrading my router to WRT1900AC.
I also wish Microsoft would confirm if they reproduced the problem (slow WIFI connection to 2.4 Ghz type N router)
Ted
2014-06-30T15:42:12+00:00 I ended up returning my SP3 since my return window was expiring. If they fix it I will try it again though. the WRT1900AC works beautiful with ANY device so it is OK and when they fix the Surface Pro 3 it should be fine as well.
I was able to revert back the driver on the SP3 and then it would work but only for a few hours, after a few hours somehow (without rebooting) the problem kept coming back, even with Windows Updates off, which is crazy to have to do anyway.
Without a solid Wireless driver, the Surface Pro 3 is an expensive brick. My $200 Nexus 7 tablet has a solid AC WiFi card, why can't the $1,500 Surface Pro 3 have a solid WiFi card? It makes no sense that Microsoft is not acknowledging this problem at least in these forums.
2014-06-30T19:26:07+00:00 yep I have not seen where they stated there was a wireless problem as well... other than when I called the surface support team they said there should be an update soon.
if there is not one this week , I am going to call back and complain. and if its not fixed within my BB return policy I will have to return it.
2014-07-01T01:28:56+00:00 Hi All,
Thank you for sharing your experiences while connecting to 802.11ac access points. We are working to resolve bandwidth limitations associated to certain access points.
Josh_F
