I've been speaking with a number of other friends/family/colleagues that also picked up Surface P3s on Day 1 and they seem to be having the same issues. 802.11ac compatibility seems to be the worst, but even 802.11n speeds seem to be worse than other stable devices.
Surface Pro 3 Slow WiFi - 72Mbps Max (driver)
I have an Apple Airport Extreme 802.11ac wireless router at home and am only connecting at a max of speed of 72Mbps (usually closer to 11Mbps if I'm more than 20 feet away from the WAP). I have two other 802.11ac laptops at home (Samsung AB9+ and rMBP) and my two other computers are connecting up at 800Mbps+ and pulling down the same on Internet speed tests; yes, I have real GigE connectivity. Is anyone else having these problems?
2014-06-21T21:28:17+00:00 -
2014-06-21T21:08:40+00:00 The last firmware update may be the cause of that. Pro 3 models received a firmware update that slowed down WiFi and you may be able to perform a REFRESH and reinstall you updates - but - this time, if you see a firmware update, click on the list link just below it in the Windows Update panel and it will display all updates pertaining to it. The one listed as FIRMWARE, right-click on it and tell it to 'hide' the update. Then, go ahead and install the others.
Eventually, that firmware update will sneak back into the updates automatically but maybe, then, it will be fixed with a patch.
I don't have a Pro 3 myself "yet" but everybody who has RT and Pro models in the past that had troublesome firmware updates had to do that for function.
Give it a shot, you don't lose your files in a REFRESH.
2014-06-21T20:54:08+00:00 So I got my sp3 yesterday and it was blazing fast on wifi. I did all the new updates and after doing so every web page was loading slow or timing out.
I did some searching and there a bunch of people with the exact same problem "Other forum"
I cant use my 5ghz network which is my wireless ac. I have a netgear nighthawk and the only way i can use this sp3 is by using the 2.6ghz now.
Please fix this. I'm shaking my head that first update screwed something up.... i already went through nightmares with my sp2 so this isnt a good start :(
2014-06-21T12:43:58+00:00 I have an Apple Airport Extreme 802.11ac wireless router at home and am only connecting at a max of speed of 72Mbps (usually closer to 11Mbps if I'm more than 20 feet away from the WAP). I have two other 802.11ac laptops at home (Samsung AB9+ and rMBP) and my two other computers are connecting up at 800Mbps+ and pulling down the same on Internet speed tests; yes, I have real GigE connectivity. Is anyone else having these problems?
I have read at least one more user reporting the same issue with the AC connection and it seems that everything started after the firmware update.
