driver_irql_not_less_or_equal (mwlu97w8x64.sys) ----> what does this mean?
2013-12-15T19:57:51+00:00
I bought Surface Pro 2 recently. It is a brand new computer. All I have done is to use it doing homework, watching videos.
But it happened several time recently, I am doing nothing, just letting it on.  it suddenly crashed and let me search for  "driver_irql_not_less_or_equal (mwlu97w8x64.sys)". what does this mean?
2014-09-05T18:06:48+00:00
Hi allenyw80,
Thank you for the reply. I understand you are having the same issue on your replacement device and I know this is a frustrating situation for you. I'm here to guide you in the right direction.
Please try the following:
  1. Back up your files.
  2. Do a reset.
  3. Go to Charms>Settings>PC settings>One Drive>Sync Settings>Turn off Sync your settings on this PC. This step will isolate the settings from other computers that might affect your Pro 2.
  4. Install all updates.
  5. Install your apps back one by one to see if the problem comes back with certain apps.
  6. If the problem continues, please contact our Support.
Best Regards,
Clare
53 additional answers
    2016-11-01T06:11:35+00:00
    I am having this problem with a Surface Pro 2 running Windows 10 Anniversary Edition.  I contact MS support  - they logged into my machine and ran a system restore.   Just got the same issue tonight while running Google Chrome.   Please provide a simple way to fix this.  This is unacceptable.
