I'm having the same issue of battery drain because of the dreaded xHCI USB (\_SB.PCI0.XHC) controller...
When it started, I thought it was caused by an application I installed, so I did a full restore of the SP3. For 1 or 2 days, it seemed to be correct. The xHCI USB controller was always making the top offender list, but it was active only for 1% of the time
so things were green.
Then it started to be active 100% all the time in Connected Stanby... I can't identify why it started to do it again. What's worse, it is with a different set of applications as I had not re-installed that many apps yet. This thing must be driving like crazy
because the SP3 case is getting noticeably hot.
It basically makes Connected Standby rather worthless as it eats up the battery almost as fast as if you would be using the SP3.
When you Google xHCI USB (\_SB.PCI0.XHC), a lot of hits come up with SP3 users complaining this is a battery hog. I'm hoping Microsoft is aware and actively working on this. I can't believe some Microsoft employees aren't using the SP3 and have not noticed
this issue.
In the meantime though, does anyone knows how to get more details of what is activating the USB controller? This thing can't decide to go crazy on its own, I assume it's activated by something. Perhaps I'm not reading the sleepstudy report correctly, but
it doesn't give any clue about what is causing the USB controller it to run like this.
