Surface Pro 3 short battery life
2016-08-15T19:41:38+00:00
Split from this thread.
I was wondering if I have a defective unit. I have an i5 surface pro 3 and I only get about 4 hours of battery life playing YouTube videos at about 40 % brightness and about 5 hours of web browsing.  The computer shuts off when I am just below 10 % battery left. What are you guys getting?
Thank you in advance for your help.
Best regards,
Jordi
    2014-09-16T20:59:36+00:00
    Ok so i've done the video play back test. If you are connected to your WiFi and Home Network streaming movies from your desktop with a balanced power settings and Bluetooth enabled. You get just over 5 hours of watching movies. But if you set to 30% display settings with the bluetooth off you get just over 6 hours of video playback. So reducing the display does help, but kinda reduces the quality of the screen.
    But i'm not sure how the iCore 5 gets 9 hours of web browsing if we can only get about 6 hours with the Internet connection turned on of video playback. I guess i'll have to test that as well.
    I'm not sure how much power does the Bluetooth consumes
    2014-11-26T20:00:30+00:00
    I get about 2 hours battery life from my Surface Pro 3.
    Has anybody here had this problem?
    2014-11-29T18:17:12+00:00
    Hello everyone.
    I just got the surface today, (i5 256) and set it up with a few average programs that I use on my laptop
    video player
    messenger
    itunes
    torrent downloader
    normal stuff that you would use.
    well, after fully charging the surface to 100%, i decided to watch a downloaded 1080p movie Zero Dark Thirty in bed.
    all programs were shut off, except the messenger app (it's called Line messenger)
    the brightness was reduced to around 30-40%, and raised to about 50-60% 2 hours into the movie.
    I was using headphones with the keyboard attached
    the entire movie was only about 2 hours and 30 minutes, but the surface shut down before the movie ended..
    WTF??
    This can't be normal can it? Please help! I was planning on using the surface as a note taking tool, but if I only get 2 hours, this can't be good :(
    Please help!
    2014-12-09T02:10:56+00:00
    I have the surface pro 3, 512GB,
    I was doing a local presentation today using Chrome (64 bit). I started with 100% charge and after 95 minutes the batter drained to 7% and died. I was on WIFI but not browsing, had MS Word open in the background, with full screen brightness.
    I know MSFT claims great battery life with the Surface, but this seems pretty poor as compared to a Mac. I know we can't compare apples to apples here, but I am wondering if I have a battery problem or does the Surface just not get great battery life?
    2014-12-09T04:55:14+00:00
    Which version of Chrome? Chrome is notorious at killing battery life on Windows Devices, Google basically uses a trick to keep Chrome's binary in CPU for a performance boost, but it never allows the CPU to idle impacting battery life.
    Where you also using Chromecast to project? Its another battery killer on Windows.
    They've been doing it for a few years and rumored to working on a fix. I use IE and Office (large Excel Pivots, Writing Briefs and Creating large decks and very heavy inking in OneNote). I get 6-9 hours of battery life.
