2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-05-23T18:04:25+00:00
    I had problems with battery consumption and the OS remaining on due to the High Performance power plan I had selected.
    Settings | System | Power and Sleep | Additional Settings, try the Balanced plan.
    2016-05-23T18:52:52+00:00
    I am using the balanced mode all the time :-/
  3. Deleted
    2016-05-26T19:33:46+00:00
    I just checked for updates.
    "my device is up to date as of 21:10 today"
    I installed the updates that's announced in this thread.
    I'm running 14342 build, windows insider, slow ring.
    I know that I really can't expect stability from preview builds, but the build that shipped with the device was even worse stability wise.
    My sp4 i5 is still behaving as described in this thread.
    It overheats and uses my battery in my bag.
    I've disabled windows hello, but the sleepmode still seems broken.
    I've run driver verifier, but got stuck in bootloop, no data to analyse from that session.
    I've tried to download intel 520 generic drivers (non whql, but newer) but that didn't help either.
    At work I'm on a mission to try to get all the ipad-users to switch back to a computer again, but the stability of this device is making my mission very hard.  It just doesn't "just work". :(
    I love the idea of this device, but I've had more problem in the last six week since i bought it, than I had in three years with my Lenovo X1 Carbon.  (using insider builds and fiddling around with setting and features with about the same intensity as on this device).
    Should i try to get a hardware replacement? Would that solve my problems?
    I felt so hopeful the 24th when I discovered that a load of driver upgrades was published on WUS, but unfortunately it didn't help.
    Sorry about the mix of constructive criticism and rant nature of this post, but it desrcibes the frustration I'm feeling quite well.
    (Sorry that this post is a reply to your post, but I couldn't find any other way to post here)
