2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-05-18T20:39:04+00:00
    I have read that there is a problem with the Intel chipset.  I assume with each fix they are reducing the number of machines that are having problems.  (I returned mine in March after the first round of fixes didn't solve the problem.)
    Note, though, that I opted to upgrade to the I7 processor as part of the warranty.  (I wanted it from the beginning but was too impatient to wait the extra month for it to be available.)
    I bought my Surface through the online Microsoft Store but took mine to the Redmond WA store when I was there for a conference.  They were very helpful and gave me lots of options.  I recommend going to a store if you have one nearby.
    Good luck!
    2016-05-18T20:48:48+00:00
    Good luck!
    So could I just ask what difference have you seen on the battery performance issue? Getting anywhere near the quoted 9 hours on this new machine?
    Thank you
    2016-05-18T20:57:16+00:00
    My Surface is usually plugged in so I don't have much battery life data.  The best example of the severity of the problem for me was that I charged it overnight, put it to sleep,  unplugged it and drove 20 minutes to an appointment.  When I got there, it wouldn't wake up, it was so dead it wouldn't even tell me the batter was low.
    Since replacing the machine, I've taken it to several similar meetings with no battery problem.  (I did once have a pen problem, thinking it needed to be charged, and I didn't use the machine.  When I got back into the office I researched how to charge the pen -- it is passive and doesn't need to be charged -- and realized I should have just tried some basic things -- lock/unlock the screen, put it to sleep, etc. -- as the pen worked fine when I got back to the office.)
    I hope some day soon to be able to rely more on the machine.  It is pretty amazing but the experience definitely has me not feeling like I can rely on it yet.
    2016-05-18T21:24:53+00:00
    Since replacing the machine, I've taken it to several similar meetings with no battery problem.  (I did once have a pen problem, thinking it needed to be charged, and I didn't use the machine.  When I got back into the office I researched how to charge the pen -- it is passive and doesn't need to be charged-- and realized I should have just tried some basic things -- lock/unlock the screen, put it to sleep, etc. -- as the pen worked fine when I got back to the office.)
    The pen is not passive, it is bluetooth connected and uses a replaceable AAAA battery.
