2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-04-20T16:50:23+00:00
    I applied the April 2016 update on my SP4 (8/256/i5) this morning. Sadly, the overheating issue still remains. Back to hibernate. :(
    2016-04-23T17:14:20+00:00
    My Surface Pro 4 M3 version always had the issue where if I put it onto a sleep mode, it would run extremely hot and battery will drain. In other words, it never falls asleep (along with the screen not turning on after putting onto a sleep, really annoying takes like 2 minutes and 10 different power button pushes to turn on a screen).
    I just did the latest update (Apr 18 2016 or something like that) but the issue still persists. This time it scared the **** out of me because I put it onto sleep mode yesterday night after fully charged, put it into a sleeve, woke up after 8 hours, and the sleeve was extremely burning hot so I took it out and the battery was about 20~25% or so.
    This is a serious issue guys. Are you guys gonna act later when it seriously burns someone's house or a room? You guys can expect some serious massive lawsuit if you guys don't do something about this.
    The machine seriously needs a critical follow-up update, a recall, or a free upgrade to Surface Pro 5 or something. This is so concerning.
    2016-04-24T15:39:21+00:00
    Hey,
    same here, Surface i5/256, latest updates are installed.
    I was really happy to read that they apparently fixed the overheating/sleep mode/battery drain issue... Finally activated Windows Hello (which by the way works great), set the energy settings back to go into sleep mode instead of hibernate, to finally have the real tablet feeling on my Surface.... closed the keyboard cover. Three hours later: My Surface is burning!!! I open the cover, battery drained down to 30% and the fan is trying to do its best to get the temperature down.
    I am really disappointed and angry that I switched from my Macbook Air to the Surface last year! And I will certainly not recommend any of my colleagues in my company, to switch to a Surface!
    2016-04-24T16:35:03+00:00
    Hi Josh,
    I have applied all recommended updates (build 1511 as of 4/24) and followed some of the suggestions on the forum. This issue is continues to affect not only me but - based on the latests comments - many others. I would also comment that not only my machine overheats but the fan runs on hyperdrive even for simple tasks as browsing the web.
    Any suggestion beyond applying the updates?
    Pro4/i7/256g
