2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-02-23T23:46:21+00:00
    I have the latest updates installed, but my Surface Pro 4 still heats up and drains its battery while asleep.
    2016-02-24T00:58:56+00:00
    How do you put the SP4 to sleep?  By closing the type cover, or from the Start/Power menu?
    2016-02-24T12:30:18+00:00
    In this case, it was by closing the cover (I had to run to a meeting). Thinking about it now, that's the only time it ever does this. I should be more mindful of putting it to sleep from the menu for now, I guess.
    2016-02-24T13:02:48+00:00
    I suspected you had closed the type cover to sleep the device.  The only time I ever had a "hot" sleep was when I did that too. And the subsequent sleep study showed continuous CPU activit during sleep and excessive battery loss. (That heat had to come from some where.)  I now take great care to sleep the device from the power menu and have never had the issue since.
    Microsoft please take note!  Sleeping by closing the SP4 type cover does not work.
