2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-02-19T19:56:55+00:00
    The sleep battery drains/heating seems to be addressed after update. But it seems that there is another heating/drains issue when wifi stand-by is turned on.
    Battery life is fine when sleep with wifi stand-by off but Surface drains quickly and get heating up with standby on, no matter plug in or not.
    2016-02-19T20:30:31+00:00
    I'm not sure what you mean by stand-by.  But this made me wonder. When the unit is in sleep mode, should I have it set so that wi-fi is OFF DURING SLEEP?  I have never done that with a laptop, but maybe that would keep it from getting warm?
    Hibernate is slower to wake up, I wonder I turning wi-fi back on after waking from sleep makes the time difference a wash.
    2016-02-19T20:40:24+00:00
    I use sleep with WiFi off during sleep, and when I wake up the device the WiFi connects in less than two seconds.  That's not a wash versus the time for hibernate for me.
    2016-02-19T21:38:17+00:00
    On Surface you can set if the WiFi stay in connection when the unit is in sleep mode.
    This is called Wifi standby in settings >system > power & sleep " stay connected to wifi while asleep"
    Turn this off, my surface is fine but turn this on, it gets hot and drains battery while asleep, which should not happen for a well-designed 2015 product.
    This function is to help update your mail or calendar change etc while asleep so your device will always be "ready to go" instead of waiting for syncing for a while when you wake it up.
