2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-02-18T23:29:26+00:00
    Here is the report:
    8% battery drain from 70% to 62% in 1hr 17min. Looks like the updates are not working me.
    2016-02-19T01:57:02+00:00
    Hi all, sadly after applying the 2/17 update, I still continue to have the following problems...
    1. When I click on the battery icon, the remaining hours are erratic. Sometimes I see 59 minutes and within few minutes it goes to 2 hours and 30 some minutes.
    2. While charging cover closed and in sleep mode, the battery was heating up.
    3. The battery drains significantly during the sleep mode cover closed up.
    4. When fully charged it is displaying that it can run only for 5 hours and 30 some minutes. I thought it should be something like 8+ hours.
    Still love my surface, but it is really affecting the day to day usage. Have switched back to hibernate options. Any help from surface team is greatly appreciated.
    2016-02-19T02:18:31+00:00
    I have the same No2 issue.
    I didn't attach the cover type but it was heating up when charging as well.
    2016-02-19T15:57:27+00:00
    I have a applied this update to two of my Surface Pro 4 machines and both of them blue screened, restarted told me I needed to recover the OS.....  It then came back on its own.  I then had issues with my wifi nic again.......
