2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-02-18T15:39:35+00:00
    Same here. I'm seeing consistent numbers. Around 140mW per hour.
    2016-02-18T15:48:36+00:00
    Is the heat problem fixed too? This morning after the update, I put it in sleep and it was definitely warm, but not hot.  My phone, when charged and plugged, has no heat.  I would think this SP4 should also have no heat if the battery is fully charged and it is sleeping.  Is this your experience now?
    2016-02-18T16:03:35+00:00
    I haven't noticed any unusual heat/warmth after picking it up from sleep. Nothing out of the ordinary anyway.
    2016-02-18T16:19:57+00:00
    Further update, put it to sleep for one hour and the drain rate was 139mW. Completely fixed.
    Edit:
    How do you run this test? After the update my sp4 battery decreased from 84% to 73% in 22min and the FAN came on due to Heat. I would appreciate your help to know how to diagnose whats causing the drain?
