2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-02-18T01:35:10+00:00
    A new observation.  Today I had my SP4 undocked, unplugged for a couple hours in SLEEP, and it did not feel warm.  If I can reproduce that, it tells me that the warmth is coming from being plugged and/or docked.  Anyone have thoughts on what that would mean in terms of a cause for it to get warm during sleep?
    There is no mystery here.  Batteries get warm when being charged.
    2016-02-18T01:48:25+00:00
    Battery is fully charged  it is sleeping,  and it is still warm.
    2016-02-18T01:59:25+00:00
    The sp4 uses some power when in sleep.  The battery will be charging continuously at a very slow rate to maintain 100% levels.
    2016-02-18T02:14:33+00:00
    Further update, put it to sleep for one hour and the drain rate was 139mW. Completely fixed.
    Edit:
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=93bf9b9f-f7b9-463a-8a3d-b846774490ee)
