2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-02-17T23:24:18+00:00
    We shall see ...
    2016-02-17T23:36:19+00:00
    Hi All,
    Josh
    WIndows (automatic) Update is now finding this release, and although the Surface update history page discusses a 2/17/2016 update the latest update available for download it the 1/28 file (as of the time of this post).
    Also, these two items' device drivers apparently are incorrectly listed on the update page.  Version v8.20.0.877 installed, not v8.20.0.866.
    • Intel® Smart Sound Technology (Intel® SST) Audio Controller driver update (v8.20.0.866) improves system stability.
    • Intel® Smart Sound Technology (Intel® SST) OED driver update (v8.20.0.866) improves system stability.
    EDIT:  Microsoft correcrted the 866 typos.  Maybe they do read these forums.
    2016-02-18T00:49:54+00:00
    Can anyone verify that the heat problem is improved?
    2016-02-18T01:23:13+00:00
    Yep, just had mine asleep for half an hour and battery drained at a rate of 224mW.
