2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-02-10T21:53:12+00:00
    Regarding the battery, I lowered the maximum processor state to 50% and minimum to 0% on battery, this didn't effect the performance that much unless you're playing games or anything processor intensive but did give me around 8 hours with casual work and around 5-6 hrs with videos. This is better than 3-4 hours I was getting before.
    2016-02-11T08:41:54+00:00
    2 Questions:
    1/ How do you go about lowering the maximum processor state to 50%?
    2/ What is the effect on battery life that we are all discussing if you disconnect the keyboard / cover?
    Thank you.
    2016-02-11T11:04:38+00:00
    This page tells you how to add processor state to the Power Settings
    Add processor state
    2016-02-11T23:37:30+00:00
    Is there a fix for the battery drain during hibernation or power off bug?
    I discovered others have the issue here
    https://www.reddit.com/r/Surface/comments/3vy4k1/surface\_pro\_4\_battery\_drain\_while\_completely/
    Below are 3 scenario's which demonstrate the issue with the 3rd scenario a work around to the bug.
    How to recreate.
    You need a Surface Pro 4 and the Type Cover.
    Go to your power options and select "Choose what power buttons do"
    Set the following for both on battery and plugged in
    When I press the power button: Hibernate
    When I press the sleep button: Hibernate
    When I close the lid: Hibernate
    Scenario 1
    1. Charge the device to 100%
    2. Unplug the charger.
    3. Make sure the surface is running and logged in.
    4. Close the Type Cover
    5. Leave overnight
    Expectation: The surface pro should go into hibernation and there should be no power drain from the battery
    Result: There was power drained from the battery.
    Scenario 2
    4. Press the power button and immediately (with in 2 seconds) close the type cover
    5. Leave overnight
    Scenario 3
    4. Press the power button and Wait until all illumination from the type cover is off (about 5 to 10 seconds). To test swipe the trackpad or press the brightness on the illumination key(F2). You know the surface has completed hibernation because the keyboard will no longer illuminate.
    5. Leave overnight
    Result: Success!!! No batter drain. The device is has successfully been put into hibernate with no battery drain.
    Anyone have any idea if this will be fixed or if MS are working on this bug.
