2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-02-06T13:32:40+00:00
    Unfortunately, almost everyone is reporting this, for example https://answers.microsoft.com/en-us/surface/forum/surfpro4-surfperf/i5256-surface-pro-4-overheats-and-battery-drains/045497f8-1ece-49b2-aeaa-8aa10994a277 - if you search this forum for "battery" you will see many threads about this.
    The best you can do is make sure you have installed all available updates from Windows Updates.
    Microsoft is working on this, and it is unknown when a fix will be available. Sorry.
    2016-02-06T17:01:25+00:00
    I completely agree Barb. But this is not a 3 usd chinese tablet. It is a toy that costed me 2415 euro yesterday with the HUUUUGE promise of 9 hours battery life. I was a Macbook Air guy for 7 years. I am starting to miss my Macbook... and only 24 hours passed so far.
    If this keeps going on my company will end up switching back to Mac and will open a lawsuite against Microsoft... and of course i will get mine since i conviced them all to switch !!!
    2016-02-06T18:06:43+00:00
    Since you bought it yesterday, you should be able to return for a full refund. I
    suspect it will take a while for Microsoft to fully fix this issue. I'm an
    unpaid volunteer, like all Community Moderators, MVP's, and I feel the device
    was released before it was ready. But there's nothing I can do except tell
    people to return it or wait until some unspecified future date when a possible
    update will arrive to improve things.
    Barb
    Windows Experience MVP
    2016-02-09T16:33:33+00:00
    When and howwill the battery drain be solved
