2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-02-01T16:46:13+00:00
    Wait.
    It is a known issue and Microsoft is trying to fix it.
    2016-02-04T22:21:50+00:00
    Why does the battery get very hot when playing  a game
    2016-02-04T23:55:48+00:00
    Hint: the faster you drain any battery the hotter it gets.
    2016-02-06T11:46:26+00:00
    Dear Microsoft,
    I was told that the surface pro 4 has 9 hours battery life. Little was I surprised to see that it does not even arrive to 3. What should I do?
    I can send you the html file with the battery report.
    Thank you
