2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-01-28T18:40:30+00:00
    Battery still drains at about 4% per hour on my i7 in Sleep after applying firmware update last night and rebooting so no deep sleep fix yet.
    After applying the latest firmware update 1/27?, the issue of battery drain and overheating still happens. What battery charging enhancements were included? i5/256/8
    2016-01-28T18:55:09+00:00
    I purchased my pro4 i7 less than a week ago and I was fully aware of the battery drain issue during the purchase. I tried 3 different methods to check how much the battery drain happens during 10hours of shutdown
    1.) First time I shutdown my pro4 and immediately closed the typecover with it. After 10hours, Next morning the battery was almost 30% gone.
    2.) Second time, I shutdown and immediately detached the typecover. After 10hours, Next morning 0% battery drain
    3.) Third time, I first turned on the backlit on my typecover. Then I shutdown my pro4. After the screen went black, I clicked on the mouse pad and saw that the backlit was still on indicating the typecover is still charging itself. I waited for another 30seconds and the backlit went off indicating the Pro4 is now completely shut. After 10hours, Next morning "wallah" 0% battery drain.
    I did step 3 two more times and same 0% result indicating that even though the Pro4 shows black screen on shutting down, it still hasn't shut down completely and hence waiting 30seconds before closing the type cover is a good option to make sure the shut down process is complete.
    I also did "Crtl + L" and waited for 10hrs. This time it was 6%-7% drain.
    The boot up does not take more than 5-8sec so I am fine with shutting down my pro4.
    2016-01-28T19:19:45+00:00
    Abu, have you gathered sleep performance data since the 1/27/2016 firmware and recent Windows 10 cumulative update?
    FYI I've always shutdown the SP4 with the type cover open, and never fold it up (unless I am moving it for a distance, in which case it's already been off for over thirty seconds).  I've liely never seen any drain during shutdown because of this, consistent with your testing and the thirty seconds wait to close the type cover.
    2016-01-30T15:32:58+00:00
    I also wait before closing the SP4 cover and think this is not just a SP4 issue.
    I had noticed that when shutting down my desktop, and several W10 laptops, that the screen goes black but it takes longer than it used to for the computer to finally shut down.
    On one laptop I had closed the lid as soon as the laptop screen went black and several hours later found the laptop had not shut down.
