2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-01-23T16:16:01+00:00
    Tried switching off again last night and sure enough the battery drain while switched off is now fixed. This is a big help but still getting at least 50% drain while in sleep mode.
    I hope this is sorted soon
    That's interesting in that there has been no update for the Surface Pro 4 for firmware since December 2015.  The recent update was for previous Surface Pro models.
    2016-01-26T15:10:38+00:00
    Yes, I hadnt tried again since previous update. I usually just set it to sleep and leave on charge overnight, only tried once (before the update) switching off overnight but since the power drained I never tried again. Now if I am travelling I will keep switched off when not in use.
    Another thing I noticed is that the microsoft solitaire pack really drains the battery. I often play this when on a break and it causes fan to come on full power and drains the battery almost 1% / min! For a simple card game (designed for Windows 10) this seems a bit extreme.
    2016-01-28T13:31:50+00:00
    Surface Pro 4 firmware update was released yesterday!!!! I am waiting for the battery to charge right now to install.  Here are the release notes:
    • Surface Embedded Controller Firmware (v103.899.256.0) adds battery charging enhancements and thermal tuning.
    • Surface Fingerprint Sensor driver update (v2.2.10.6) improves accuracy.
    • Wireless Network Controller and Bluetooth driver update (v15.68.9037.59) improves access point compatibility and throughput on 5Ghz networks.
    2016-01-28T14:59:56+00:00
    Battery still drains at about 4% per hour on my i7 in Sleep after applying firmware update last night and rebooting so no deep sleep fix yet.
