2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-01-21T20:17:59+00:00
    I love the surface pro 4 but the battery issue is terrible. I lose 50 - 60% battery overnight, this is just useless when I travel as I need to charge it every 12 hours even if not in use. Even with it switched off Im losing a huge amount of battery overnight.
    I have all the latest updates and tried all the fixes I found online. If they dont sort this soon Ill be returning it to Microsoft.
    2016-01-21T21:00:38+00:00
    Fully shutting the SP4 down (rather than sleeping or hibernating) with the keyboard either open or not attached stops battery drain.  The boot time is 8-9 seconds for me, so although it is not optimal it is a workaround that is practical.
    That said, where is the "reported" fix for this that was supposed to be out on 1/19/2016?
    2016-01-23T13:37:47+00:00
    I am looking forward to the day when the announcement says....
    Surface Pro 4 Updated Firmware Released To Fix The Battery Drain & Sleep Issue!!!
    Everytime I turn it off I don't know if it will turn on!
    Also 9 hours of battery life....SURE!
    I am a MS user since 1989 (Started with DOS) but seriously address this issue Mr. Panos!
    2016-01-23T15:34:28+00:00
    Tried switching off again last night and sure enough the battery drain while switched off is now fixed. This is a big help but still getting at least 50% drain while in sleep mode.
    I hope this is sorted soon
