2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-01-17T17:33:30+00:00
    The last thing you said is correct. Surface will not go into sleep immediately even though you give the sleep instruction. It depends on the settings of "pc goes to sleep after XX minutes"! If this settings is 10 mins, surface will still run on high activity after you push the power button until 10 mins passes. This is so weird! There are too many buggy designs of windows 10 which cause bad user experience!
    2016-01-19T13:40:39+00:00
    It pains me to think this, but given the novel-length list of unfixed problems spanning more than a YEAR (beginning with preview versions) across both desktop and mobile versions of the OS, not to mention the apology of a browser called Edge, our hopes should not be high.
    2016-01-19T16:36:32+00:00
    There are several posts around the various forums that the driver fix is supposed to be released today (as suggested in a recent post elsewhere on this forum pointing to Paul Thurrott's site).  It appears we've been waiting for Microsoft to certify the was released by Intel on December 22, 2015.
    We'll see.  It's not in Windows Update yet, and no Microsoft pages mention this update.
    2016-01-19T22:36:49+00:00
    Yeah i'm not too sure whats going on, I hope they push this update out today. This problem is really killing my enjoyment with this great device.
