2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-01-14T05:00:19+00:00
     I heard from some sources that this issue is not from Microsoft, it is from Intel's Skylake chipset design fault.
    I seems to be hardware related and cannot be fixed by firmware update. Only fix could be replace the Skylake chipset. I suggest whoever has SP4 which is still within 30-day return period do return the device and wait for a few months to buy it once the Skylake is mature.
    This return period is not relevent if, in fact, it is a hardware issue that requires replacement.  It would be a patent defect.
    2016-01-17T12:27:10+00:00
    Guys, apologies if this has been mentioned but we may have a (partial) solution, as discovered by kevinmyexp on this Reddit thread: https://www.reddit.com/r/Surface/comments/417hwr/sp4_sleepdrain_suddenly_get_fixed_on_mine/
    Essentially, for some reason enabling Hyper-V in 'turn windows features on or off' seems to allow the system to enter DRIPS, with no CPU C0 time. I tested this last night with a 3 hour sleep before hibernate and the system lost 4% battery with a drain rate of 550mWh. I am doing a longer test now, but for me 1-2% per hour is an acceptable sleep drain rate, considering my phone is somewhat similar. I have the 'stay connected to wifi' turned OFF for this also.
    Something to note is that the first few times I tested this with a shorter sleep time of less than 30 mins the drain rate was higher. It seems that the system shifts into a deeper sleep after 30 mins or so. I am not sure of this though, and will keep you updated.
    2016-01-17T13:15:03+00:00
    This isn't a solution as enabling hyper v on a surface brings up other issues,  mainly with connected stand by.
    On mine,  with hyper v enabled,  if the surface is put to sleep,  once it wakes,  WiFi doesn't work until after a  reset.  The only fix  for me is to completely Uninstaller hyper v.
    More details at the link below,  and a fix that works for some,  but not others
    https://tomssl.com/2015/01/15/fix-the-wifi-on-your-surface-pro-3/
    2016-01-17T15:59:22+00:00
    That's interesting. So far I haven't had any issues with wi-fi or screen flickering which seem to be the problems associated with hyper-v. I'll keep watching out.
