2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-01-09T21:54:35+00:00
    My Surface Pro 4 (i5/ 8GB / 256GB SSD) has the same problem - battery drain even when the unit is off. It drains about 7% - 8% per day. I contacted Microsoft Support a few times and spent hours with support staffs for the past 3 weeks. I finally got a replacement last week. The replaced unit is having identical problem. I doubt this symptom can be resolved by firmware update. It could be hardware / component problem. Microsoft should admit this and recall units. If they keep on ignoring this, - "Surface" brand will soon be history!
    2016-01-10T00:27:49+00:00
    I agree - there are way too many bugs with the hardware or software.  I can't believe MS has not released an update to fix some of these since Dec.  If this was Apple - the press and everyone else would be going crazy.  They release fixes much faster and have less to fix.  Seems like Apple is held at a higher standard.
    I think the SP4 is a cool device, but my return period is next week and will have to return if some type of fix is not made.  Bet they get a lot of returns then with the holiday return period ending soon.  Really too bad, as I want to keep it, but way too many bugs to chance it.
    2016-01-10T13:30:42+00:00
    I don't know if this will apply to you, but I resolved the same problem on mine by using the power button instead of the cover to hibernate the device. I did quite a bit of experimenting and it seems the problem is definitely related to the lid close option. When I used the lid to shut off it drained around 5-10% overnight, with the power button near nothing. I think it is also important to make sure the Surface is completely off before closing it.
    Seems to be software related for sure, hopefully this will be addressed in the elusive power management fix, assuming they are even aware of this problem...
    2016-01-11T04:29:12+00:00
    Thanks for the tip.
    I did shut down the unit with the power button. Close the lid does not shut down the system. It only put the unit to sleep.
