2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2016-01-03T02:17:46+00:00
    Hi SH ,
    Me too,my new SP4 is bloody useless ,bought it to work on stock markets and assured the battery life was fine...it is a piece of **** ..2 hours this morning and it is flat and running far too hot...not at all suitable for purpose ,plus some settings keep changing..Bloody pen has failed already,hope it is just the battery ,compared to the MacBook I was using this thing is a dog.
    For 2k it is a bloody joke.
    2016-01-03T08:05:39+00:00
    I just bought a surface pro 4, and i works fin but, if I put it to sleep with 100% power the next morning it is totaly drained. no battery left,
    I got all the latest updates
    help plece
    thanks
    2016-01-08T06:35:34+00:00
    I am having the same problem with battery drain when shutoff.  Cant comment on the sleep problems but I have used my Surface Pro only for a few days after owning int for 6 weeks. All updates are complete. Plugged in and used sparingly for 1 day and then shutoff at 100% charged. 3 full days later tried to power it on unplugged and it wouldnt turn on. Then connected the charger, powered on and it shows at 0%. Date is wrong too so the battery must have been completely drained after being fully charged after 3 days. Please help.
    2016-01-09T12:29:52+00:00
    Can  Microsoft please give us an update on what is planned on this issue or what we need to do step by step please?
