2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-12-23T11:53:33+00:00
    I have the same battery drain issue. SP4 i5, 256/8. Changed to hibernate instead of sleep. It is little better. Has Microsoft confirmed that it is due to Windows Hello? I do have them turned on which is pretty neat feature.
    Too many problems for such a premium device with a premium price!!! I had to return my first unit since it's touch became spotty within a day. Then I ran into the battery drain issue. Then I figured Maps do not display roads, which is a known issue.
    Is anyone testing these products before general availability or was it rushed?
    I have never used Windows Hello.  It has never been enabled.  My SP4 has the sleep battery drain issue.  It is not a Windows Hello issue.
    Well; I was really doubting that anything will be done to repair the battery issue before I returned my SP4 but yesterday I called Microsoft and behold; the tech actually assisted me to repair the issue.  There was a hardware update awaiting install and after we installed the update and the tech reinstalled my battery drivers it looks like things are as they should be when the system is in standby and hibernate. Actually there was 2 hardware updates pushed out and each of them was dated for December 17 so check and see if you have these updates installed or awaiting install.  Not sure what cured it, the updates, the battery driver reset or both!
    I have been monitoring the system for about 18 hours and it has not dropped any percentages due to hibernate or sleep mode.  Of course this did not suddenly give the overall battery performance much improvement as I think the battery performance is dependent on how you use the device.  For me I like bright screens so I cannot count on anything over 4 hours for my use.  Kudos for Microsoft
    2015-12-23T12:25:18+00:00
    Has anyone tried disabling Hiberboot?
    It's in HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Power
    Change the value of HiberbootEnabled to 0 (from 1)
    2015-12-23T13:21:41+00:00
    Hi do you have a link for those new upgrades as can't see anything for 17th December?
    2015-12-23T14:25:10+00:00
    Could you please post the version, date and exact name of the battery driver from device manager?  (I only see one hardware update from 12/17.)
