2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-12-19T12:32:48+00:00
    Same as everyone. Sleep and battery issues.
    2015-12-22T04:57:03+00:00
    I am having the same issues. When in "sleep" mode, the battery drains in hours. I always find the computer blazing hot in its sleeve. Also it doesn't matter how long it is shut, it will never go into hibernate. This is a pro4 i5/256. Before this I had the pro 3 and never experienced this issue. It could go weeks without being charged.
    I have since changed all the setting to hibernate which helps with the battery drain but is a real pain to not have the quick on. This is a major flaw that needs to get fixed. Please fix my favourite device!!
    2015-12-22T21:03:57+00:00
    I have the same battery drain issue. SP4 i5, 256/8. Changed to hibernate instead of sleep. It is little better. Has Microsoft confirmed that it is due to Windows Hello? I do have them turned on which is pretty neat feature.
    Too many problems for such a premium device with a premium price!!! I had to return my first unit since it's touch became spotty within a day. Then I ran into the battery drain issue. Then I figured Maps do not display roads, which is a known issue.
    Is anyone testing these products before general availability or was it rushed?
    2015-12-23T00:25:02+00:00
    I have never used Windows Hello.  It has never been enabled.  My SP4 has the sleep battery drain issue.  It is not a Windows Hello issue.
