2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-12-16T17:11:52+00:00
    If you are shutting down the device, AND then losing charge, then I would try turning off Fast Startup. What might be happening is that the device is trying to save its state, and can't, so it sits there spinning sucking up battery life.
    This a power management issue, not a "trying to save its state" issue.
    2015-12-16T17:49:50+00:00
    Call it **** you want. I don't have the issue, but there are many out there that do when trying to turn the device off. I'd exchange it if that were the case.
    2015-12-18T01:20:30+00:00
    So i read the note to surface customers and made me wonder if there are Surface pros out there that dont have any of the issues some are going thru. Should i take it back to the store and get it replaced?
    Any thoughts?
    2015-12-18T17:48:25+00:00
    Thank you for reaching out to the Microsoft Surface community. Could you please tell us what issue are you experiencing with your Surface Pro 4?
