2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-12-12T00:36:05+00:00
    The issue is not hibernate or sleep. The issue is hibernate causes battery drain! Why does Microsoft keep avoiding the subject of these devices either losing battery while off or in hibernation mode. It is filled with bugs.
    See this thread.
    https://www.reddit.com/r/Surface/comments/3vi355/sp4\_losing\_battery\_while\_hibernating/
    2015-12-12T00:44:45+00:00
    They're not avoiding the issue. Microsoft has openly acknowledged it and states that they are working on a fix.
    2015-12-12T14:42:41+00:00
    Just to let you know that I think the Surface Pro 4 is a truly remarkable piece of technology and I am over the moon with it.
    But and it is a big BUT I purchased this from Currys PC World in the UK for a high end price and on the basis of being able to play video for up to 9 hours. That is a battery intensive function and I doubt I could get much over 3 hours out of this right now! That's a big leap and I trust you will make it.
    Apart from that it is brilliant.
  4. Deleted
