2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-12-10T17:43:09+00:00
    I'm running the latest Insider Build and if I hibernate at night with 100% battery, it wakes up in the morning with 100%.  I'm seeing no battery loss in hibernation.
    Hi: I am not exactly sure what "insider build" really means or if it should make a difference but I have a different question that also relates to the battery drain:  I have noticed that the fan has started staying on while conducting minimal tasks, such as scrolling through Facebook posts.   Last night it stayed on for nearly 15-20 minutes at a high speed.  I also noted that the battery was low (around 25 percent) when it came on.   My unit is an i5 with 4 gigs of ram
    I had issues with the fan coming on when I purchased it along with the battery drain and a Microsoft tech reset all of the drivers and the issue went away but it appears that it might have returned.  It is becoming a very difficult task of trying to decide whether to keep this device in hopes of Microsoft fixing these issues.  Carrying around an expensive tablet whose fan blows and batteries only last a couple of hours is not what I would call sensible.  Your thoughts on this please!
    2015-12-11T05:27:20+00:00
    In order to be able to hibernate, you need disable connected standby and can then select Hibernate from the Power menu.
    2015-12-11T12:35:32+00:00
    You don't need to disable Connected Standby to see Hibernate as a power option.
    Control Panel -> Power Options -> Choose What Closing The Lid Does -> Change Settings That Are Currently Unavailable -> Check 'Hibernate' in Shutdown settings
    2015-12-11T20:43:44+00:00
    Thank you for your open and candid responses. Right now, our team is working hard to address your feedback as soon as possible and we’ll communicate on this thread whenever an applicable update is available. We also now have a sticky thread here on the main Surface forum page that we’ll refresh when applicable updates are available. In the meantime, we suggest that you set your device to “Hibernate” instead of “Sleep.” Thanks again for your feedback!
