2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-12-08T17:15:17+00:00
    Yes, MS is totally aware of this issue. A power mgmt fix is coming "early next year."
    2015-12-08T18:15:49+00:00
    I'm running the latest Insider Build and if I hibernate at night with 100% battery, it wakes up in the morning with 100%.  I'm seeing no battery loss in hibernation.
    2015-12-08T19:41:56+00:00
    That's because when you hibernate your system is completely off. If you have a desktop try to hibernate and disconnect with power and it would still work.
  4. Deleted
