2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-12-07T13:50:33+00:00
    I have set hibernate enabled from the start/power button. It's clear from the batteryreport that something is using mwh's between when the device is suspended and when it is active again.
    I just cannot figure out what it is.
    2015-12-07T17:38:17+00:00
    Well, I have been on the phone with Microsoft twice now and nobody told me it was a know issue. In my opinion this is a basic functionality that should be thoroughly tested before releasing the surface. I might return it in the next days if it keeps bothering me
    2015-12-08T16:41:01+00:00
    The biggest issue that I think people aren't paying attention to is that the surface pro 4 uses battery while in hibernation!
    Check the battery report when it hibernates. Between suspended state and active state, it typically uses about 150 mwh per HOUR.
    Therefore, even though we can limit battery drain from putting the device into hibernation, there is still battery loss, which should not occur in hibernation since the device is supposed to be powered off.
    I have not seen Microsoft even acknowledge this issue, even though there are reddit threads about it.
    2015-12-08T16:53:48+00:00
    I've seen these reports too. Does turning off Fast Startup help? I have not seen my SP4 draw power during hibernation, but I have Fast Startup turned off.
