2015-11-04T01:55:47+00:00
Split from this thread.
2016-02-17T23:04:09+00:00
Hi All,
Josh
434 additional answers
    2015-12-06T22:23:15+00:00
    While I think it's also a shame that MS released the SB and SP4 with these issues, they seem to be tackling the issues quite fast. I'm willing to give them a month or two to fix the power issues. They already fixed the Intel driver issue for many (not all) of us. I would definitely get an exchange, though, just to keep your one month return period running until they come up with the power fix, otherwise, you may be stuck with a device that you may not want later on.
    2015-12-06T23:50:07+00:00
    They have fixed some issues but caused others.  My testing with the replacement device shows they actually caused the sleep battery drain issue with the 1511 and associated firmware update.
    2015-12-07T12:55:46+00:00
    This is really terrible. Sleep mode basically does not work. In my case the fault is not from Hello because I simply didn't even have a way to configure it. The only solution seems to be to change the behavior when closing the lid/pressing the power button from "Sleep" to "Hibernate". It then takes ~30 seconds to log back in from hibernate which is not what I am used to in another machines but it's better than having your Surface "turned on" all the time.
    2015-12-07T13:20:52+00:00
    This is a well documented issue. Microsoft is aware of it and is working on a fix for early next year, which is good news. I was going to return it because of it, but knowing that it's just a bug and not a hardware issue, I'll keep it! I think that's my only big issue. All the little things will get ironed out. Just give it a little time.
